dgadee
Planning to blast hull prior to coppercoating. How do you mark the line between underwater and topsides? Gouge a thin line?
Could you please explain how to recreate the waterline from the 3 referenced marks. Genuine interest from me thanksIf you mark the bow and each side of the transom then you can recreate the waterline afterwards. We tend to use a fine saw to make a subtle scratch mark.
Aye - it is amazingly/surprisingly accurate! Better to hand sand the last few mm than end up with ‘textured’ topsides.After blasting I'd be very surprised if the mark wasn't clear. Any blaster worth their salt won't go above the line meaning that it will be very apparent
Number of different ways. If you have enough space either side of the boat then set up a laser and join the bow and transom mark (obviously repeat for the other side). Another option is to use a water level set up on one mark and then use masking tape to put marks along the side. The other method is to use string lines running from battens set level across the bow and transom, each time you contact the hull use masking tape to make a mark. Hopefully you should be able to find video/images to explain as it’s tricky in words!Could you please explain how to recreate the waterline from the 3 referenced marks. Genuine interest from me thanks
Thank you for taking the time to explain it. I think I understand the theory.Number of different ways. If you have enough space either side of the boat then set up a laser and join the bow and transom mark (obviously repeat for the other side). Another option is to use a water level set up on one mark and then use masking tape to put marks along the side. The other method is to use string lines running from battens set level across the bow and transom, each time you contact the hull use masking tape to make a mark. Hopefully you should be able to find video/images to explain as it’s tricky in words!
