Daydream believer
Then in the morning you struggled to recall their nameIs it true that whenever you took a girl out you called them Stella
My first one was brand new & that as far as I can recall, did not leak when first launched.The yard launched my Stella and phoned me at work about 1hrs drive away.
"We've launched your boat, she's leaking and we're all going home. You had better get here."
It would make a good thread . "Your worst calls from a boat yard".The yard launched my Stella and phoned me at work about 1hrs drive away.
Did you think it was wise to go out for a sea trial when you knew that there was water in the engine oil?This is what happens in a marina if an automatic bilge pump is not switched on.
I looked at a boat in a Marina which was for sale. The boat was supposably being looked after by a local boatyard. When I pulled the engine oil dipstick out the colour of the engine oil was white indicating that there was water in the oil. The engine started very well and the person from the boatyard took me out to sea for a sea trial where the engine stopped working and we had to be towed back. Air in the diesel.
After I bought it I found the boat had a badly drained cockpit and during heavy rain water would get into the bilges.
To counter that an automatic bilge pump had been fitted, two batteries and a battery charger plugged into an electric point on the pontoon.
I believe another boat owner had removed the plug from the marina pontoon power point, for a time and when replaced it the RCB had tripped, the battery charger no longer kept the batteries topped up, with the result that the automatic bilge pump no longer worked. Over a period of time the water in the bilge kept rising, and when it reached the point where the dipstick went into the dipstick hole water started to enter the sump, oil then would have started to float on top of the water and spread. The starter motor was filled with this white oil mix.
Not all boats have auto bilge pumps, they don’t seem to sink. In fact perhaps auto pumps result in complacency, therefore fewer checks and dead batteries = more problems than theysolvemask.
[/QUOTE]The real questions that if a marina has a no auto pump rule and your boat sinks due to rainwater ingress the marina would be liable for any damage and cost of recovery.
The same if a boat gets damaged due to the mooring breaks up and sinks or damages the boat like what happened to mine several years ago.
In my case being a steel boat the only real damage was to the paintwork and my anodes prevented further corrosion
If you’re talking about conventional cruisers, motor or sail, or even daft trimarans, sure. Our DF bilge pump is left on, but it has as far as I’m aware, never run in anger. We test it occasionally, to check it's still there. But about half the boats in our harbour are essentially open. RIBs, dayboats etc. If your auto pump fails with one of those, you are literally sunk. And it happens fairly regularly.I don't get this insistence on automatic bilge-pumps. A properly maintained boat will not make enough water to sink her under any reasonable circumstances, and there are well-documented circumstances where automatic bilge-pumps have contributed to a sinking by hiding a leak that should have been fixed; sinking occurring when the automatic bilge-pump failed either because batteries were exhausted or shore power interrupted - indeed, someone earlier in this thread gave an example!
I have a conventional stuffing box, so there is a tiny amount of water coming in from that. But it is far from enough to ever need more than a few strokes of the bilge-pump to clear it.
If enough water is coming in to justify an automatic bilge-pump, then something needs fixing - and it isn't a bilge-pump.
I guess that's true. But how did such craft manage before automatic bilge pumps existed? And most day boats don't have a reliable power supply for such things. When my father owned a converted lifeboat, which had a non-self-draining cockpit, I think the cockpit was covered when the boat was left. Apologies for the vagueness - I was about 10 at the time, 60-odd years ago!If you’re talking about conventional cruisers, motor or sail, or even daft trimarans, sure. Our DF bilge pump is left on, but it has as far as I’m aware, never run in anger. We test it occasionally, to check it's still there. But about half the boats in our harbour are essentially open. RIBs, dayboats etc. If your auto pump fails with one of those, you are literally sunk. And it happens fairly regularly.
I don't think that can apply. The argument would be why owner did not make provision to safeguard boat against such eventuality?
Cost of recovery - "Wreck Recovery" is the usual term - is usually a required part of owner's insurance to get a marina mooring. That's why even 3rd Party only Ins usually has this included.
Only if the Marina equipment failed - if its owners' ropes / cleats etc - then Marina is not at fault in any form.
If damage to another boat due to failure of another boats gear - then its Owner-to-Owner claim ...
