EASLOOP
Good Morning all.
This is a question regarding mainsheet handling.
My East Anglian is rigged with a horse carrying a single pulley, 2 further pulleys either side of the after deck and a cleat on both sides (I'm sure there is a proper name for this - my tiller passes under the horse). However, in order to handle the mainsail it is necessary to free the mainsheet on the upwind side of the boat to let the mainsail assume its position, and vice-versa. To switch to the opposite tack though is a bit tricky as it involves handling each end of the sheet separately and carefully lest the whole sheet end up on one side of the boat. It also involves jumping around the cockpit somewhat. I would much prefer to use a sail track bridging the tiller, but closer to the cockpit, and to use a single down-haul. the former rig provides for 5 anchor points on deck (inc. the cleats), but the latter only one, two when the down-haul is cleated off.
If any knowledgeable sailor can recommend/advise on the best approach to handling the mainsheet/sail I would be most grateful to hear from you.
Thanks in advance
rgds
John
Thanks in advance
rgds
John
