Refueler
It does look a little low at the stern compared to the drawing in the sales brochure.
Presume there's no water in the bilge/the bilge is totally dry? Sometimes there is a false bottom/floor under the engine, and you can have water trapped under there and not know about it.
No the engine bay floor is hull bottom. I know that because a VDO impellor log is fitted through that floor.
The stern section is actually a strange design ... its as if three boxes are glued together. The largest being the centre engine box ,,, then a box either side creating the beam of the boat.
All three boxes are open top ....... but the two side smaller boxes do have an angled bottom hull creating the V hull. That is sealed and when we had to repair due to the larger engine cracking the joint both sides .. we found it to be a few cms depth till internal floor found, its like a shallow triangualr box section ... I have all the photos on IMGUR .. but I see that IMGUR is in trouble with UK so will have to upload direct .. let me look ..
and so on ....
