snowleopard
cat with 1 engine & 2 rudders. sounds like the nightmare scenario. even worse than one i met a while back - twin engines and centreline rudder - at least he could steer with his engines! the principle of number of props = number of rudders should be burned onto every designers brain. it may be heavy and expensive but i can tell you that 2 props & 2 rudders, 17 ft apart, make it harder (but not impossible) to make a prat of yourself!
incidentally i did say 'as fast as necessary' it's the people who show off by doing it at a charge that i'm getting at. control linkage failure does happen, more often than you'd expect!
