Mhvoiceuk
I currently have a Mercury 5hp long shaft outboard which I use with my permanently beached 10ft GRP tender. I usually leave the tender on my (swinging) mooring when I go sailing and put the 5hp engine on the outboard bracket - so that I have an emergency engine in case of main engine/tiller failure. The 5hp engine is bit heavy to shift around and I would like to get rid of it and buy a lighter 3.5hp long shaft instead. I have an inflatable in a valise on board and would like to be able to use the 3.5hp engine with that too. The long shaft works OK with my GRP tender although it does push the bow up and I have to keep the revs low. A couple of people have told that it's a bad idea to use a long shaft with an inflatable, but I wonder what thoughts folk here might have?
I also wonder whether it might be possible to adapt the transom on the inflatable to take a removeable, slot-in piece of timber which would raise the transom to accomodate the extra shaft length? I've never seen anything like this and I'm surprised that it hasn't been manufactured (or maybe it has)
