xhurleyman
Can someone give me information about the performance of these boats. How they sail etc.
Thank you
Thank you
The later version is the Scanyacht 290, made in the uk.
Cygnus SCANYACHT 290 - Cygnus Marine
The LM28 was built by different organisation based on LM27 outline design. it has bilge or fine keels so more easily steerable and probably less underwater drag. It may I think have a finer bow too
Hardly surprising considering the much higher SA/D of the Moody versus the LM, never mind the Longer DWL. In higher wind speeds, the Moody will still have the longer DWL, greater beam and stability and, consequently, will still be faster.I've sailed in company with an LM owned by a friend ; I think a 28. Unsurprisingly, my Moody 31 walked away from it on a comfortable beam reach, which I'd expect to be the LM's best point of sail. I'd echo the comments about them being motor-sailers with reasonable (though not sparkling) sailing capability. The difference in speed might be less in a stronger wind; I got the impression it was canvassed for comfort rather than performance. The accommodation is excellent, though somewhat unconventional.
part of the charmLos roll like mad.
All except the earliest LM27s have wheel house doors. They do not have a bridge deck unlike their semi clone Scanyacht290, but can readily be fitted with a dam inside the doors. Ok a large plank maybe 150mm high bolted to bottom of door frame.Yachtsnet archive page has info about their sailing qualities and the differences between them. I'd go for a 28 if you can get one, a bit more room & the wheelhouse has doors where the 27 I think does not. They're good quality boats and well suited to sailing in UK weather...
I wonder what the comparative WL entry angles are for the Pentland and the LM? I kinda doubt they are that far apart. The Pentland does have a longer effective WL. A blunt nose will o course slow you down to weather. But, downwind? As far as blunt bows go, it does not get any blunter than the traditional Dutch models and they have been known to kick the stuffing out of much more pointy modern designs.Nominal SA/displacement of LM27 ios same as Westerly Pentland. Our Pentland would do 6kt easily in good winds and maybe 6.5 in thevrare goodwind/flat sea situation. Running down an F6 in big rollers our LM27 failed to touch 6kt and stayed about 5.6 which is max what it does under power. The bluff bow limits speed
