Llangollen Canal Aqueduct
Stemar
12 Sep 2001
Very interesting, but I won't be going there,
a) Jazzcat won't fit
b) Madame still hasn't forgiven me for taking over mountain(ish) passes in Wales with 20' drops on her side of the road I think she'd throw me off the edge if I took her there
Mister E
16 Nov 2015
I have walked across it was quite interesting.
In a program Julia Bardbury got on the outside of the boat over the drop. I thought the man driving it was going to wet himself.
veshengro
23 Jan 2023
Very interesting and thought provoking too as far as dating goes. In the year the Aqueduct opened Admiral Lord Nelson was duffing up the opposition off Cape Trafalgar. :giggle:
Neeves
20 Nov 2011
Sydney, Australia.
Cast Iron troughs in fresh water are pretty long lasting!
Not one of those useful bits of information that is any use today....cast iron troughs??
There is an idea they used to boil the pieces in whale oil, to prevent corrosion - but I think, sadly, the idea has been de-bunked (to protect whales?)
Jonathan
rotrax
17 Dec 2010
South Oxon, Littlehampton and Wellington, NZ.
For many years I lived almost next door to Walter Wilders 17th Century Iron Foundry in Crowmarsh Gifford. Walter Wilders foundry made the metal bits for Jethro Tull's horse drawn seed drill which started mechanised farming in the early 1700's.
If you go to the Tower of London, plenty of very old drain covers and grids made from cast iron can be easily found in the Tower grounds. Many have 'Walter Wilder, Crowmarsh Gifford' cast into them. Some could easily be 200 years old, are not rusty and are still serving as humble drain grids and inspection covers.
A stark contrast to the cheapo pressed steel inspection covers on my foul sewer at home. One has a corroded hole in the corner after just 40 years, and it is under a car port which keeps the rain off!
Cast iron is a remarkably durable material. Its heavy weight, brittleness and energy requirements for moulding make it unfashionable and expensive these days, plus small local foundries are less common.
The Bridge at Ironbridge is another example of its durability.
Bouba
6 Sep 2016
SoF
It just shows that it was a new day yesterday
rogerthebodger
3 Nov 2001
rotrax
17 Dec 2010
This item, made from very fine decorative cast iron in the Coalbrookdale style is 125 years old. The Angels and Cherubs were still very well defined.
It is a very finely decorated indoor planter. I inherited it with a house we bought. It was red rusty and looked appalling. A quick wire brush left no loose material on the surface so I finished it with some satin black aeresol.
I sold it through an antique FB site for strong money very easily.
It looked pretty much like it must have done when new.
