PCUK
Apologies to Duncan for partially sidetracking his post. After all the advice from all the different sources I have come to the conclusion that I should stick to what I know and use Lead Acid for the starter battery. Say 105ah plus two Lead Acid (leisure) batteries about the same for the house and another separate smaller Lead Acid battery for the fridge. All separated using VSRs and a 1-2-Both switch for selecting the house battery in use. Then just change them every couple of years as they die!
The boat is a restored beyond new Reinell V-204 at 26 ft originally (now 28ft with the extended hull bathing platform that I built on). Originally a 1978 boat now totally restored and ready for relaunching next spring. Everything is new including the engine and drive and 150 amp alternator (not smart). Let's not mention the lack of economic sense - I did it cos' I wanted to! It will be based somewhere on the Bristol Channel. Currently hoping to get a pontoon mooring in the not too distant future at Burnham-on-Sea Motor Boat and Yacht Club or as a second choice Watchet. The boat will mainly be used at weekends and odd days hopefully with much of that time at anchor and occasional long cruises to the South Coast, Ireland and West Wales.
All opinions on the proposed set-up gratefully received. Peter
