rob2
I have just got a new mooring on the Hamble. Its a pontoon between piles and the Harbour Authority require that the boat be noored with breats and springs to the pontoon and bow and stern lines to the rings on the piles. It has been suggested by a mooring contractor that I should use a length of chain onto the ring to minimise chafe. I'm considering different ways of doing this so as to minimise the numer of shackles , which I think could be the weak points in the line, especially if they are always in the surface layer and prone to corrosion.
I guess ideally, I'd have a large link on the end of the chain, so I can slip the chain through, like a dog's choker, on the ring and then shackle to the line to the boat. Just on cost alone, it's not easy to get such a link fitted whereas I have some lightly used 8mm chain lying around. A section of chain could be just threaded through the ring and the line shackled to both ends of the chain. Of course, the shackle (and eye) should be galvanised and needs to be moused.
Anyone got any good advice or tried and tested wrinkles for this?
Rob.
Rob.
