Life really does suck......
boatone
29 Jul 2001
Just a few cables from Boulters Lock
www.tmba.org.uk
Well, two problems solved today and both with the aid of vacuum technology.
1. Changed the oil in my two AQD32A's and used one of those vacuum tank thingies hired for the day from my friendly local chandler (Steve at Chertsey Marine-nice guy) for a very reasonable £10. Couldnt believe extracting eight litres of oil from each engine could be so clean and easy. Pity I didnt do quite as good a job of pouring the new stuff in but cest la vie...the engines could do with a good exterior clean up anyway./forums/images/icons/smile.gif
2. 'Flushed' with success I moved on to task number two...trying to extract the crud from the bottom of my 115gallon diesel tank. My P32 has been Thames based for years and, as a run down to LImehouse and St Kats at the end of the month is bound to shake things up a bit, I decided to try and remove any solid 'refuse' rust bits etc that might be lurking on the bottom ready to get all shook up and block the fuel filters.
My newly developed DTVC (diesel tank vacuum cleaner - of which more later} worked beyond my wildest dreams and I extracted over half a kilo of solid dross from the tank in about half an hour - all accomplished thru the fuel gauge sender hole and without without having to drain the tank.
Just for once my day was one of negative pressure...who said life sucks....????
<hr width=100% size=1><A target="_blank" HREF=http://www.boatsontheweb.com/galleryframes.html> BoatsOnTheWeb, Photo Gallery, Chat Room</A>
Renegade_Master
27 Jan 2003
Spain
Off to St Kats a,....... good luck Tony and I hope Maggie enjoys it
<hr width=100% size=1><A target="_blank" HREF=http://www.suncoastmarine.co.uk>Sun Coast Sea School & Charter</A>
ArthurWood
21 Jun 2001
SW Florida
Tony - you had more luck than I did with a spherical sucky thing. It was clean, but not very easy even sucking hot oil up thru a tube pushed down the dipsick pipe.
BarryH
31 Oct 2001
Surrey
Oh rite, so you done it then. Just spent an hour two of us clearing the dreaded bug outta filters......all good fun!
boatone
29 Jul 2001
www.tmba.org.uk
Better out than in..........
Bag of crud weighs just over a pound !
Golf ball gives some idea of the crud volume !
This is a sample taken from the tank after about 30 mins of 'hoovering'. There is some fine residue which has settled at the bottom.
Question for Dom........as this whole exercise was conducted by sucking fuel out of the bottom of the tank, through a coarse filter and then returning it to the top of the tank I would expect any water present to still be in suspension and to eventually settle. Will Soltron take care of this water residue?
hlb
RIP
Any Pub Lancashire or Wales
Re: Better out than in..........
Tony you do more provarocating than Happy1. No I cant inflict that on you, can I!!
That diesel looks orible. Just stick some Solly in it. Cant say it will gobble all the various crap you have in there. But try taking a sample a week or two after.
Haydn
DepSol
6 Oct 2001
Guernsey
Tony please please don’t bin that crap. I want it for testing.
Soltron will aid in releasing the water from your system however, we have no evidence to prove this and I cant guarantee anything on that subject. We just know it happens but don’t know by what quantity. Can assure you soltron will assist in breaking up the left overs.
<hr width=100% size=1>Dom
2003 is going to be a good year for me
duncan
Home mid Kent - Boat @ Poole
can't compete on crud (yet!) but the diesel in the filters looked way worse.....as Barry will testify!
Now about this diesel tank sucky thingy.......I was just going to use my dingy bilge pump but you seem to have a better option?
