tugboat
Last year I purchased a boat which came well equipped with Lewmar STs - a mixture of 40s, 30s and 16s. Prior to the delivery trip I serviced the primaries and secondaries (i.e. not the coachroof jobbies) and reassembled with the correct lubricant. As the months have passed, the winches I serviced have become increasingly stiff, whereas the ones I left alone are as before. The stiffness has been traced to the self-tailing crown assemblies, the stripper rings are now very tight on the top crowns and creating a lot of friction. When I did the service, I washed everything in paraffin (to degrease) and I'm now thinking I shouldn't have dunked the plastic bits. If I made a mistake, I'm keen to avoid doing it again. I downloaded the bumf from the Lewmar website prior to service (very little detail) and I've twice emailed them to ask for advice, but they haven't deigned to reply. I thus throw myself upon the mercy of all you learned folks. Has the paraffin made the plastic expand or contract in some way? Do I need to replace just the stripper rings or the whole top crown assembly on each winch? I feel they are too tight to be lubed. Did I make a cockup using paraffin, should I have just washed in clean water? This is my first experience with 'proper' winches, only had single speeds before. All advice gratefully received. (PS. Aren't those pawl springs little buggers?) /forums/images/graemlins/grin.gif
