duncan99210
Came through the canal today from the north. There's a lot of work going on in the entrance basin but it shouldn't affect transiting boats. However, the spit has crept eastwards somewhat and seems to shelve rather than have the sharp drop off of previous years. So instead of keeping close to the spit and well away from the port buoys, I'd suggest a wider approach, somewhat closer to the single remaining port buoy. When we came through there was a jack up platform putting in shuttering underneath the walls of the castle: again not a hazard but it could be as the work progresses.
Dredging is still taking place in the channel south of the old rubbish tip. There are two dredgers at work with attendant spoil barges and tug boats, both working in the channel. At present both are working the island side of the channel.
The northern dredger has a number of what turned out to be surveying poles off to the island side: these look as if they could mark a safe passage. They don't! Safe passage is to the mainland side and on closer inspection is marked by small white buoys to the mainland side and small red buoys to the island side. Difficult to spot. The southern dredger thankfully has no poles and it is clear that the safe passage is to the mainland side.
Clearly, both dredgers will move as the project progresses but it may not always be clear where the safe passage is, so take care.
