UV radiation would be a problem but only if you get sun so you could rule that out living in the Netherlands. Rain shouldn't be a problem on the hull as it would run off quite quickly. (I wouldn't leave it immersed in water though)
yes i was more thinking about the UV
Polyester based GRP is UV stable.
Sorry Paul you are wrong. (BUT the exposure to UV radiation would have to be prolonged)
The Effects of Weathering on Mechanical Properties of Glass Fiber Reinforced Plastics (Grp) Materials
This work has revealed that the decrease in the mechanical properties of GRP under weathering conditions is subjected to atmosphere conditions such as humidity, temperature, ultraviolet radiation and pollution.
https://www.researchgate.net/public...Glass_Fiber_Reinforced_Plastics_Grp_Materials
You should read the start of the paper presented on that page. The only reference to polyester is in the abstract. A very similar sentence at the start of the actual paper uses the word plastics, not polyester. Also the paper then explicitly refers to carbon fibre reinforced with epoxy matrix (not sure if they got that the right way round.....)
I'm not wrong, i suggest you do some more Googling.
Try looking into translucent GRP roof panels, for instance.
I don't need to do googling as Bruce Robert-Goodson (a yacht designer) warns of U/V degradation during construction: maybe you should set him straight!!
What is Gelcoat
Simply stated, gelcoat is the outermost structural layer on a fiberglass boat hull, designed to protect the underlying fiberglass layers. Gelcoat is a compound that produces a high-quality finish on fiberglass surfaces and incorporates a lot of chemistry,using epoxy, polyester resin, a catalyst, and other chemicals to achieve its strength and water-resistant properties. When cured, gelcoat combines with fiberglass to produce a smooth and durable surface that retards hull weakening from water intrusion and ultraviolet light.
Paul
Obviously you would never admit you are wrong. Up to now I would get cross when OP were critical of your comments but not anymore. (That is sad because I always thought you were one of the experts)
You should stick to your area of expertise and don't express views on subjects you know nothing about.
NOTE
I have no idea why you have brought the composition of gelcoat into the argument but:
Gelcoat or 'Gel Coat' is a material used to provide a high-quality finish on the visible surface of a fibre-reinforced composite. The most common gelcoats are thermosetting polymers based on epoxy or unsaturated polyester resin chemistry. Gelcoats are modified resins which are applied to moulds in the liquid state.
OP:
I think you'll be fine to do that without any worries IMHO.
Coopec:
This is a tricky subject for most of us, UV is a far more aggressive beast in Western Australia and I dont think anyone would blame you for highlighting a concern, but Paul is indeed one of our experts and he's corrected you (or set the facts straight for other readers) with time served knowledge.
I wouldn't take that as a personal attack, dare I say a bit of googling gains a wider field of knowledge than just this forum alone and helps us brainstorm and deliver the right path forward for the OP and for future Googlers.
