Motor_Sailor
Could you give us an example of one of these boat manufacturers recommendations?
Bolts are sized to transfer their full load to the hull structure. Torquing is as per normal bolted joint as the static loads imposed by fully torqued nuts must by definition be less than the breaking strain of the bolt. The washers / backing plates / structural members are designed to handle those loads.
Every time you see examples of where keel failures have resulted in the bolts pulling through the hull structure, the verdict is always the same - inadequate load bearing structure, not over tightened keel bolts.
There's no conceivable reason to use power tools to tighten keel bolts as the threads should be clean and in good order before reassembly by hand. The reason I would actually forbid it in a job spec with stainless steel keel bolts is that you could completely miss any signs of the threads galling. The primary worry when assembling large keel structures is that a bolt will gall and a highly expensive keel assembly will be ruined.
