alt
If there's a better alternative to genuine Volvo impellers for a KAD300, i'd be all ears. I replace mine annually out of habit and it seems a shame! Either way, I remove the impellers every winter (boat is out of water) and they do indeed maintain their 'bent' forum after being in the engine 6 months. It does seem a bit crazy to be replacing an impeller after 6 months (maybe 70 - 80 hours) use.Neoprene for raw water.
nitrile is much harder , wears out quicker, distorts quickly, cracks quickly and wrecks very quickly if run dry.
nitrile is oil resistant which in my opinion is a useless quality for a raw water pump.
neoprene tends to be much cheaper and is far superior, will last 5 years in leisure application compared with a season with nitrile that even if never used will distort and crack in the housing.
it’s a long time since I owned VP but back then VP supplied nitrile as standard , throw away the nitrile and install neoprene
