Just pictures
Aquaboy
12 Jun 2019
I sail alone so camera on auto (a basic digital) and its why its always calm in my pics. Then I use snipping tool to make the file small enough to upload so quality drops.
johnalison
14 Feb 2007
Essex
That's fine as long as you are happy, but you might like to do a little adjustment. Some auto modes will allow you to do this, though not on my 'toy' Canon. I have taken the liberty of partly adjusting your shot of Wivenhoe, because I live there. If you look at the histogram below, you will see a gap on the left, showing that blacks are being given as greys, and on the right a column where all the highlights have piled up and information is lost. If you look at #135 you can see how good the lifeboat's wake looks with all its tones.
Kukri
23 Jul 2008
East coast UK. Mostly. Sometimes the Philippines
You can do that with a “water tractor” tug. She is the stern tug; she makes fast and the ship tows her to the point where she is wanted. Since a water tractor, unlike a conventional tug cannot be “girted” and capsized, it’s perfectly safe, and when instructed by the Pilot she can immediately apply power in any direction.
Habebty
16 May 2001
Norfolk/Suffolk
Thanks for that, I did wonder!
Tomahawk
5 Sep 2010
Where life is good
What stops her from girting?
Pull sideways and surely she will go over?
OK the master can apply lots of power towards the tow and take the strain off the line at the turn of a dial but does that necessarily make girting impossible?
Kukri
23 Jul 2008
Position of the hook. A single or twin screw conventional tug must have her hook (or winch if she’s a seagoing tug) roughly amidships so she can alter course when towing. A water tractor can have the hook well aft or well forward (it doesn’t matter - she can exert her full bollard pull in any direction) so that an unfair load will make her swing into line with it.
Aquaboy
12 Jun 2019
Conventional tugs usually tow with a pivoting hook mounted on the centre line. This was brought in to reduce capsize risk. As the tow gets out of line so the hook swings to the side which tends to lift that side of the tug and counteracts the heeling especially if the bow of the ship is much higher.
Tractor tugs tow on a winch which is controlled from the Bridge so they can constantly adjust the pull and let go if things go haywire.......which they do......tug hook.PNG
