Roberto
I have a problem with a manual jabsco toilet : the sea water intake side of the pump seems not to be working.
I opened the whole thing (how can it be it did not smell at all?) under the pump handle, replaced the broken o-ring of the pump piston, cleaned the upper rectangular rubber membrane with the small openings, lightly greased everything, etc etc. There seems to be no air leak around the rubber membrane when the six screws are tight.
With the lever in the flush position, the pump is unable to draw sea water, not even a single drop. The sea water intake hose and seacock have been cleaned and water passes freely. I tried priming the pump by taking off the intake hose from the seacock and plunging it into a bucket of water above, but to no avail.
I poured half a bucket of water in the bowl and the pump evacuated it with no difficulties. (That s how we ended up using the toilet).
Any ideas?
Any ideas?
