mikehibb
Not realy boaty, but many have them.
Over here in Tbilisi from mid 1990s until early 2000s power was terrible, first couple of years we only had 5 hrs per day, 2 in early morning, 3 in early evening. So we bought an open frame Honda 2.5kw, any way that eventually moved to the summer house and as power impoved we could manage with a smaller (quieter) genny.
So we bought a Honda SH1000DX suitcase genny (original honda, not the chinese copy), used it at home (2 bedroom apartment) a couple of hours a day a couple of times a week. Then we moved to Baku in 2005, and it just got pushed to the back of the balcony, and there it sat. We moved back to Tbilisi a couple of years ago, and we have generally 24 hrs power 365 days a year.
However during the last two weeks we have had two nights without power due to breakdowns in the HV infrastructure ( oh here we go again) and winter is coming.
So yesterday managed to dig the old genny out, not run in over 5 years.
Changed the oil (old stuff did not look to be in too bad condition but not worth the risk) and gave it a slow pull on the starter (switched off), and it turned over smoothly, looking good.
Today bought some new fuel, filled the tank, turned it over a few times whilst switched off again to help move new oil around and prime the fuel system.
Then the big moment, 5th pull and she came to life again. Ran for a couple of minutes on no load, switched off and restarted first pull. Ran again on no load for a few minutes, checked output was ok just on my multimeter. Did not want to load it up at this stage, tomorrow will run again for a couple of minutes and then change oil again (0.5L sump so simples to do) Just wanted to get the oil around and remove any nasties.
Made up a new power lead tonight too ( old one was looking a bit dodgy), so can hook up to the house tomorrow and give a full load test (was not going to disturb the neigbours this evening either) so fingers crossed for tomorrow afternoon.
So hopefully all will go well, these little Honda machines are brilliant.
The SH1000DX is the predessessor to the EU Inverter type range, heavier, but still with full regulated speed control, not the type with a tortoise and hare load settings.
With the old 2.5 unit we could run the fridge/freezer and all the lights and TV (we had Kerosine heaters then, no Gas in the city 10 years ago either).
We would then disconect the fridge/freezer and run the electric immersion heater for a tank of hot water etc. (Bottled gas for cooker)
We now have city gas supply and cer/pump running. Fridge/freezer is OK as long as we get mains power back withntral heating, so the 1000 is enough to keep a couple of lights,TV and Boiler/pump running. Fridge/freezer is OK as long as we get mains power back within 24 hrs.
Must admit after reading some of the other generator threads on here, I am amazed at the size of gennies that some use on a boat (mobos especially, but we do not have air conditioners to run, well we do, but just do not use them, on a big boat in the med you would need a bit extra if away from shore power obviously)
So feeling pretty chuffed with myself today. Just hope that we do not need to use it too often this winter, at least we are prepared. That is part of the trick, hopefully now we are all set up again we will not need it.
Enough of my ramblings. Mike.
