DavidBolger
Hi,
I need some help with my batteries and charger.
I have three batteries on board. 2 for the domestic and one for the engine. They were with the boat when I bought it and were replaced in 1998. They seem to be heavy duty commercial batteries. There is no amp hour rating on them but it says 700 amps cranking power and reserve of 180 minutes. I also have a 15amp merlin shore charger which is on all the time I am in the marina. The owner before me was also in a marina and had the charger connected at all times. I have maintained the batteries, topping up with water and cleaning the posts. Over the last six weeks I have noticed that the shore charger is "cooking" the batteries. They get very hot and you can hear the electrolite bubbling. My initial conclusion was that the batteries were shot and that this was a classic case of seeming like persistant overcharging. I did a specific gravity test and the results were just in the red zone. When charged the batteries read 13.7v and when I turn the charger off (I brought them home and used a car 6amp charger for 24 hours), the voltage drops to 12.5v. However, when I did a load test I cranked the engine for 15 secs and the voltage drops to 11.3v and stays steady (which I believe is a sign that the batteries are ok).
The merlin shore charger is one of these three phase chargers, red light - bulk charging, yellow light - equalisation, green light - float mode. I have noticed that when the batteries are hot and electrolite bubbling the red light and the green light are both on but both are less bright than when they are on separately.
So whats the answer, are my batteries shot? If so how do we explain the healthy load test? Or is the charger acting up? If so how do I fix it?
Any help is gratefully accepted but please be technically gentle as the above is pretty much the limits of my electrics knowledge.
regards
David
regards
David
