Inverter versus 12v charging
oldvarnish
15 Jul 2005
I have a piece of equipment which requires its battery to be re-charged now and again. It's quite a small battery, and if using an inverter the manufacturer says that an 80W inverter is sufficient - so it's not hungry.
Various leads (supplied) give me the option of charging it directly from the boat's 12V supply, or with a mains charger plugged into a small inverter.
These are my questions:
Will the battery charge faster via the inverter, or from the 12 v supply (when the boat engine is not running and assuming the batteries to be 90% charged))?
Is it more efficient to charge via the inverter or directly from the battery bank.
Please give you answer on one side of the paper only.
bedouin
The speed of charging will be more a factor of the device batteries rather than how it is supplied - so it should charge in the same period of time either way.
All other things being equal, efficiency should favour the simpler solution - namely the directly from 12V. With the inverter you are wasting power converting 12V DC into 240V AC only to convert it back into DC again - that additional stage is going to increase the losses although with the efficiency of modern circuits it shouldn't make much difference.
elton
19 Oct 2005
Durham, England
www.boatit.co.uk
It's always more efficient to charge from 12V rather than using an inverter.
I won't have anything on my boat that requires a 240V supply. There are always 12V alternatives.
Whether it charges faster on 240V vs 12V depends entirely upon the charger. Using the same charger, it's unlikely to make any difference.
