AllanG
Can anyone recommend a teak wood filler (especially for a good colour match) that can be used to fill small screw holes in an interior cabin area?
Many thanks, Allan
Many thanks, Allan
When I last sanded my exterior teak I ended up with quite a lot of teak dust which I kept, partly because I thought it might be useful to mix with clear glue and use for this very purpose. I have never tried it, but would be happy to make a small quantity available to the OP for experimental purposes on the sole condition of a report back as to the success or otherwise of the project.
I don't think the OP wants to cover the screw heads, he wants to fill the holes where the screws used to be.
I have had success with these, rub into holes, mixing the shades leave to harden then polish off.Can anyone recommend a teak wood filler (especially for a good colour match) that can be used to fill small screw holes in an interior cabin area?
Many thanks, Allan
http://www.familynotices24.co.uk/11778681
I got the veneer from Mitchell Veneers & Components in St. Albans - the panel I needed to repair was quite small and they were able to sell me an adequate offcut at a very reasonable price. I have a small amount left over - PM me with the size of the panel you need to repair and I'll see if I have enough.
If it's too large to completely cover, you may be able to do a marquetry fix if you have a steady hand and a good eye - I can certainly let you have a few square inches of veneer if you want to try that!
It is very unlikely that you will be happy if you use any filler to fill the holes. I have filled hundreds over the years and IMHO the only way is to use a teak bung and then varnish.
You can buy bung cutters in various sizes to suit and any old teal will do to make a new bung.
Tom
Thanks for this offer, Maby, but as the holes are only from screws for old instruments, then I think I may try Brummer Stopper filler.
Cheers, Allan
I think you may have posted the wrong link, as this one leads to an obiturary website??!!
If you can find a piece of teak get your sander and generate some dust,mix with Resin W or other PVA adhesive to form a paste.Works well.
