Whitelighter
Ah ok,
A Brian in Bournemouth help me out with a Swedish matter a few years ago.
Wondered if you were him.
On the contrary...
However, if water getting into the f/b ignition switch is _not_ a latent defect (poor design of switch?) then what was the cause given as?
Cheers
Jimmy
Yes but I am pushing the threat of formal complaint to the FOS.
I think thats fairly common. I've just checked my policy document and there is no detailed list of conditions attached to it other than specific exclusions related to my boat. Maybe somebody knows better than I do but is there any consumer legislation requiring insurance companies or brokers to send a complete policy document with any renewal?However im insured with the same company, i have just checked my policy details and they have never sent me this .
Incidentally when we sorted out Seahope's sinking case last year on here (a) the ombudsman threat was made very carefully in a non ranty way (b) we got the surveyor's report and it actually contained paragraphs that if read carefully (rather than cursorily, as insurers had done) helped Seahope's case (c) we made a proper argument as to why he was covered under the policy not just a rant and (d) we won.
Having seen some eye wateringly large invoices I am very pleased with (d)
JFM remember the offer I made still stands.
any links to your issues ?
JFM sounds to be a bit of hero! Talking of which, is that JFM's boat in his avatar? very jealous![]()
I am certainly no expert on the subject but that was the view of two independant engineers whose opinions were accepted. I can't really add to that.Bit of Thread drift I know, but...
Warm air inside the console and cold air outside caused condensation to form in the ignition switches. The heating was turned off overnight and the drop in temperature caused the moisture to freeze. It was this that shorted the switch and started the engine.
Hang on a mo.... it it's condensation , then thats basically distilled water and hence has a high resistance (assuming theres not a load of salt inside the switch to dissolve).
High resistance would not allow sufficient current to flow to allow the start solenoid to energise and start the engine. ???
To my mind, that theory seems a bit questionable (I would say 'holds water' but perhaps better not!)
Just to claify, the flybridge console had a fitted vinyl cover and in turn the flybridge itself had a fully fitted cover. No water was able to directly enter the ignition switch. The cause was heat from the boat's heating system being transmitted up to the flybridge console, the main culprit being the stainless steel tube from the engine room to the flybridge through which the control cables ran. Warm air inside the console and cold air outside caused condensation to form in the ignition switches. The heating was turned off overnight and the drop in temperature caused the moisture to freeze. It was this that shorted the switch and started the engine.
I had owned the boat from new (well ex-demonstrator) and had had it 16 years, 15 of which was as a live-aboard. It wasn't a latent defect and had never happened before or since up until I sold the boat last August.
Jim
Please let this be the last post on my problems which has drifted this thread off its original course but just to say some of your assumptions are wrong in that the boat was steel, the engine room was mainly above water and was in fact heated.
