eebygum
According to the Lewmar website:
http://www.lewmar.com/products/index.asp...number=49016001
The mounting instructions state "5 x M6 (1/4 in) c’sk head screws on 94mm(3 11/16in) PCD. Lewmar recommend that the rope enters onto the drum at an angle of 5º to 10º to the base axis of the winch. To achieve this angle it may be necessary to use a base wedge when installing the winch."
Any help with my dumb questions ?
(A) what is a PCD ?
(B) The base angle of 5 to 10 degrees - is that up/down ? it's going to be at an angle from the genoa sheet up to the mounted winch on the cockpit anyway ?
(C) How important is getting (B) right in respect to the efficiency of the winch (on a non racing, short-handed boat) as the detailed 'Fitting and adjusting your Winch" instructions in the pdf file listed on the same page don't even refer to achieving this angle and using a base wedge ?
Any help appreciated as given the expense I want to get them right.
(A) what is a PCD ?
