CharlesSwallow
Ah, OK.
I'm pretty sure I read an article or articles by Wild Venture's owners in the NAVA newsletter - I passed them all on to the new owners when we sold our Venturer so I can't check.
(Just to clarify the situation re: chopped strand glass mat - you can get "powder bonded" mat that is suitable for use with epoxy, but it will be described as such. Ordinary "emulsion bonded" doesn't wet out with epoxy and probably what you would end up with by default if you didn't specify otherwise. For what it's worth, if I were doing the repair, I would definitely use epoxy.)Andy
NO. You need to use something with the same flexing characteristics(coefficient of restitution etc) as the original opthalic polyester resin used in the original construction. Epoxy eventually cures to a substance much more regid than poly resin and therefore shearing at the interface is much more likely for no particular strength benefit. "Hard spots" should be avoided and certainly NOT be intentionally introduced.
I know every inch of that boat. After all I owned it for many years and I noticed that even some of my original mods were still there. If the original webbing support is just beefed up she will continue well into old age. Since our "rigourous" ownership she seems to have had a relatively quiet life; partly on Rutland Water and now on an inland paradise in SW france.
Chas
