Buck Turgidson
If the aircraft is in your house there are more pressing issues than what nav kit got it there!!
My understanding is that airliners use a variety of systems for local and long distance navigation so are not reliant on GPS. These are:
-ADF The Automatic Direction Finder resembles a compass with a large arrow in the center. The pilot selects the frequency of a non-directional beacon station, and the needle points to the station.
- VOR A Very High Frequency Omni Directional Range resembles a compass with a bar hanging down the middle. The pilot rotates the bar until the needle is centered, and that will guide the aircraft to the VOR ground station.
- INS The Inertial Navigation System is set by the pilot before taking off. The pilot sets the coordinates of his present position, and using a variety of gyroscopes, the system will keep track of the aircraft's position throughout the flight.
- GPS The Global Positioning System uses a series of satellites that calculate the aircraft's position. The GPS unit provides a display that shows the plane's position on a map.
- Compass The most basic tool is the standard magnetic compass.
Are thermionic valves effected by solar radiation and EMP?
Of these, the only one that could be immune to a BIG solar flare is the INS.
Any newish comercial aircraft will have an integrated navigation system offering Area Navigation (RNAV) capability meeting at least some of the ICAO Required Navigation Performance specifications which are currently being implemented globally but on different time scales.
The concept is that the integrated system meets a declared navigation accuracy and you use it on procedures which require no more than your system is capable of.
The more critical procedures require systems which monitor themselves and alert the crew when accuracy is degraded.
The most accurate and therefore critical in terms of terrain clearance type of procedures are promulgated on dual DGPS. Some states require an IRS as a fallback to get away from the terrain in case of GPS failure. Others don't.
If anyone is really interested in the facts about GPS vunrebility to solar flare then pop over here: http://www.navcen.uscg.gov/?pageName=GPSSOI or have a read of the EGNOS safety of life service document here: http://www.essp-sas.eu/service_definition_documents
Just in case the worst happened, it's comforting to know we've still got a Strategic Steam Reserve.
in the MoD sheds at Dunkeswell, till about 5 years ago, there were dozens of Green Goddesses. Now all gone to Withams.
I think that the point is that a flare like the Carrington Event would probably even kill systems like "Fly By Wire" - never mind navigational systems. I strongly suspect that the majority of aircraft would be grounded as a precaution in the event of such a massive flare.
If it kills 'fly by wire', there's going to be chaos on the roads as well.
When did you last drive a car with an accelerator cable attached to the pedal?
People seem to be missing a number of important points here.
Aeroplanes and cars operate inside the ionosphere. Not much gets through that, even in a big solar event.
Aeroplanes and cars are pretty effective faraday cages, not much of that small amount of radiation will get through.
Aeroplane designers will (surprise!) have thought of this and designed against it. FBW effects are certainly not something that the manufacturers even bother to mention to their pilots so one can assume the risk is as close to zero as makes no difference (as opposed to temporary loss of GPS which could be a mild annoyance in the airways, and possibly as much as a nuisance if you wanted to land off a GPS only approach and no other aids were available, which is about as likely at the moment as it interfering with the FBW because there are so few such approaches.
Nowhere else on the internet can I find any mention of a current solar flare that is more severe than usual, certainly there is no concern whatsoever out there.
Methinks this is all a solar storm in a vacuum tube...
