jamie langstone
As per our conversation make sure the sea cock inlet valve is in the off postion then poke the fresh water hose in to the strainer in the gearbox cooler side and start the engine so that it pumps water . The water should then fill the water strainer up as the engine pump does not suck up the water faster than water hose can deliver. Let the water keep filling the strainer up so it over flows now pull the hose out so that you are filling from the top of the strainer and then stop the engine but keep the water flowing. Yes i know the water will be going in to the bilge but as soon as you start the engine again it should start pumping again . I normally squeaze the pipe a bit to reduce the flow when the engine is running so that there is not to much water going in to the bilge.
The most inportant thing is to make sure you have that sea cock inlet valve closed or most of the water will be going on the floor as the boat is on the hard stand.
Before you but the boat in the water make sure the sea cock is closed and the strainer is full of water and the sealing cap is tight.
I have placed a link below with the style i have in my MF805 with the clear lid which makes it alot easer to see what is happening to the water .
VETUS water strainer - Cooling water strainers - Engines and around the engines
