vas
share vyv_cox concerns and also slightly confused.
I'll just focus on the suggested use of a non-positive displacement pump for sucking water off even a 30cm pipe (doubt it will be closer than that)
I understand that this will only work if said pump is placed below waterline so it will be able to slosh about water and eventually moving it up to the heat exchanger (hopefully)
is this your plan? Even a sketch diagram would help. Don't confuse your useage to a closed circuit one on a car engine. not quite the same. Abrasive properties of seawater also rather different to nice glycol/whatever mix car engine coolant. Why do you think that bearings in the 25quid pump will be up to the job? Decent ss bearings and seals even on the smallest of sizes are probably about that, how come this one has an el.motor as well at that price? I know it's mass produced but so is SKF bearings, replaced my yanmar 2GMF ones wasn't that cheap!
I'd make sure the overheat and oil pressure switches/warnings are setup properly and working before embarking in this.
