VicS
But you cannot bypass the pump ... can you ?If you suspect the fuel pump, you can feed the carb from a remote tank by gravity.
You can buy little plastic 'tanks' for the purpose, it's handy when you work on old motorbikes.
A 3HP engine should only be using of the order of a litre per hour, so a burette improvised from a 50ml syringe should run it for a while at low load.
You can raise the burette on a metre of tube to be sure there is enough pressure supplying the carb, I doubt much is needed.
Even a length of tube with fuel in it would show the carb drawing fuel to keep the float level correct, or not.
The other thing to be sure of regarding the pump would be is it leaking air into the crank case?
