I seem to have a leaking exhaust pipe from diesel heater
27 Dec 2022
No need for googling. I you would have read the thread, you would have known that not all wallas heaters are designed like that. And this particular heater is one of those with a simple exhaust hose.
[193211]
2 Aug 2022
My bad. Unlucky you got duff one. No advantage to having an expensive heater with expensive spares. The install looks v ropey. The low point requires a drain.
27 Dec 2022
The recommended Youtube part 16 shows this one (y)
Seems expensive, alternatives exist/can be made.
So I watched the video now. In the first 3 minutes he states spesificaly that "you cannot just drill a hole at the bottom, it will cause exhaust gas inside your boat". Surely you can make a drainage lock yourself with a piece of pipe, a fitting and some copper tube... I`ll consider it ;)
