AntarcticPilot
Hydrogen is the very devil to store - it leaks through almost anything. The only reasonable ways to store it are as liquid, or in solution. The pressurised gas is extremely difficult to store.
Slightly off topic but there is an excellent YouTube video interview of Lord Bamford discussing their rationale for pushing hydrogen. It’s aimed at, as has been said, heavy plant running 24/7 in shifts where downtime to recharge electric isn’t feasibleI'm with Lustyd on this.
How many boats sit in the marina all week, or for a couple of weeks and are then used for a day / weekend?
I would say the vast majority fall into this category, and for that use case this would be a viable approach once the generation process becomes viable.
JCB are spending millions on Hydrogen generation / storage and hydrogen engines as electric engines are not suitable for building sites / roadways etc. They see hydrogen as the future.
JCB.com | Hydrogen
An alternative would be that the Marinas invest in the generation / storage facilities and we go to the fuel berth to replenish. Or maybe a combination? Generate what you can and top up from the marina.
I agree that fuel cells are a more elegant solution, but hydrogen isn't the only or even the preferred feed for them. Ammonia is one; easily liquefied and transported and non-flammable; it has a lot going for it. There's also a lot of work going into fuel cell designs which can accept a wide range of feedstocks; these should be much less delicate than the present generation.Bamford love him or hate him is an astute businessman and has successfully driven JCB into the truly international company that it is now making inroads into the truly heavy plant market. He clearly or rather his development engineers and research department see that there is a future for Hydrogen driven plant and I rather suspect that it will as the major Japanese car manufacturers do will eventually play an increasing part if not the dominant part in domestic and commercial vehicles.
The question mark surrounds the production and distribution which is slowly, very slowly being addressed the danger being that EV with charging points gets too much of a head start and hydrogen "propulsion" becomes one of those good ideas that get left on the shelf. However I believe that ultimately the EV as it is at present will be an evolutionary dead end or at least the large batteries that power the motors will and other fuels be they hydrogen or ammonia will form the energy reservoirs that provide the power to drive the motors so that whilst investing in EV production manufacturers are hedging their bets because it should be possible to swop out the batteries and charging systems for fuel tanks and fuel cells.
A fuel cell is basically carrying out an oxidation reaction in such a manner as to produce an electrical current. So in principle, any fluid or liquid that can be oxidised in an energy releasing reaction is potentially feedstock for a fuel cell.
Pretty big commitment!
British firm JCB signs multibillion-dollar deal to import green hydrogen
An interesting idea. Please report back with real world performance results when you have built a working system.Just had a thought on powering a boat. Given the idle to in use ratio of boats, and the proliferation of solar it seems like it might make sense to use electrolysis to produce hydrogen which can then power the boat instead of diesel. Wikipedia suggests around 40kWh/kg which means that a 1KW panel might make a kg every 5 days, equivalent to around 5l petrol. Given that the power is otherwise wasted it might be a reasonable approach since even a small motorboat could fit 2-3kW of panels which ought to produce enough juice for the weekend trip out. The water can obviously come from the sea, albeit via a small watermaker, but the quantity required would be tiny so could theoretically all fit in a compactish unit.
I think most of the technology was based on brittle things, even the semi-flexible ones. Fully flexible will evolve but it is more logical for investment to focus on static installations initially. I think different substrates will become cheaper in future.Does anybody know of a solar panel material that could be made into sails?
And I can understand chemists fairly well ? I did part 1A chemistry in the Nat Sci Tripos; my late wife had a PhD in electrochemistry, and we could hold intelligent conversations on chemistry. But my understanding of fuel cells comes from correcting research papers about them, and I have to be careful what I say as I work under non-disclosure terms. I think we both agree that for practical reasons, hydrogen is unlikely to be the fuel of the future; there are far more practical alternatives that don't require cryogenic storage or extreme high pressures, and which don't leak through the walls of storage vessels ?That has all the makings of a "Lakesailor" ?
You may have failed to notice that somewhere towards the end of my rambling I did mention ammonia and have done so on many previous occasions? Additionally although you are not expected to know it but it has been mentioned periodically I am by education a chemist.?
Hum bit dark and pessimistic? Oil availability is way over 50years. Much better prospect than larking around with hydrogen gasCurrently...
