Poignard
I have two tiller lines, like tent guy ropes with tenioners, as used by Eric Hiscock. Cheap, simple and capable of fine adjustment.Even a dead tillerpilot will help with the first three. For the last one, I'd hove to, using the dead autopilot to hold the tiller in place
The important thing is that you can fix the tiller so the boat points more or less in the right direction, even if it's only a bit of string. If your tiller steered boat would keep going in roughly the same direction when you let go, you're a lucky skipper. Mine would usually go off at full lock in whichever direction would cause the maximum inconvenience
