How to remove this old mast foot?
Captain Crisp
1 Mar 2015
Hi I'd like to replace the wiring inside my 50yr old mast...
Do I just drill out the rivets and prise it out?
Thanks...
Crisp
If you are lucky you may be able to prise the plug out. (use a carefully calibrated bashometer) Probably need a cold chisel or similar to get pressure on to it. In the end I suspect you will have to cut the ali of the mast. Try about 1 cm and peel off the mast ali from plug. That may a enable the plug to come out. if not cut more. Yes you will have to shorten stays or pack the bottom of the mast to allow for shorter mast. ol'will Funny just wwrote same thing re a boom plug.
A good long soaking in penetrating oil, eg PlusGas, might help too.
If you do find your mast is corroded at the bottom (although yours looks much better than mine did), you can have a reinforcing sleeve welded onto the outside. You can just see the top of it in this picture, level with the top of the teak chocks:
Nice welding.
I try to do a neat job on mild steel- I wouldn’t know where to start with aluminium - I know TIG welding needs a bit more skill - that I don’t have.
I was similarly concerned about getting my mast foot out ... but in the end - once screws were out - it actually came out quite easily.
Careful use of wide blade screwdrivers in the joint eased it out ...
Most Alloy masts to the cast foot - seize with oxidised powder ... which usually is not so hard to break hold by taking a mallet and knocking the alloy around the fitting ... even literally knocking the fitting into the mast ..
Looks like OP's fitting is riveted ? Basically drill out the rivets or remove the screws ... problem with rivets is that the body still remains locking the fitting in place so need to get a 'drift rod' of correct size to punch the rivet body through ...
Different foot - but similarly inserted into mast base ..... (this is after repair) :
Out and ready to repair :
After about 15 years I had minor corrosion at the base of my mast. I cut off about 1cm just above the screw line which gives access to the lip on the plug and makes it easier to remove. I was able to keep the existing rigging as there was easily 1cm of adjustment. Refit the plug with lots of grease or anti corrosion sealant and keep the drain hole clear if you have one. I had no further corrosion in the next 25 years.
If you don't have a mast cable conduit the cables will slap against the mast and keep you awake at anchor. If you remove the base plug you can fit cable ties or pipe insulation on the cables to keep them quiet.
