How to attach ensign to flag pole??
Chas25
9 Jul 2004
Tried searching in Google and haven't found anything /forums/images/graemlins/frown.gif
Can anyone give instructions as to how I acheive this?? Can't be that hard /forums/images/graemlins/confused.gif
Keen_Ed
13 Dec 2002
Is this a proper ensign staff, with cap and cleat?
Like this?
Get a piece of thin line that's about twice the length of the staff, or a bit less. Thread through the sheeve in the cap - up from below, and back down, so that both ends come out of the bottom of the cap. In one end of your halyard, tie a small loop - use a bowline. Thread the toggle on the ensign through this loop - you want a small loop so it can't shake itself out. The other way to attach the halyard is with a clove hitch around the toggle.
Tie the other end of the halyard to the loop at the bottom of the line sewn to the flag - use a sheet bend. Cleat both ends of the halyard to the cleat on the staff, making sure that the ensign is stretched tight, and hard up against the sheeve in the cap. Use a round turn on the cleat, and then a figure of eight. Finish with a locking half hitch.
Chas25
9 Jul 2004
Thanks! Think I'll print this out and cross reference with book of knots to make sure I do it right!
It is a proper ensign staff, but its stainless so not quite the same think it has a hook at the top and a loop at the bottom... or maybe the other way round!
cliff
15 Apr 2004
various
Or one could use a Splice Nut /forums/images/graemlins/ooo.gif
"Artificial intelligence is no match for natural stupidity"
sailroom <span style="color:red">The place to auction your previously loved boatie bits</span>
DAKA
7 Jan 2005
Nomadic
/forums/images/graemlins/shocked.gif
Must be a builder or a sparky to come out with that.
Nails would rust in days and split the pole.
Two Stainless counter sunk bolts drilled through 2 inch apart at an angle of 45' could be used if the cleat is absent.
DAKA
7 Jan 2005
Nomadic
I thought he wanted to do a proper job /forums/images/graemlins/wink.gif
I am sure he could have worked out the easiest way was just to knot it to the sports boat obligatory Jolly Rodger (cable tied to the VHF mast no doubt) /forums/images/graemlins/tongue.gif
Major Catastrophe
31 May 2005
Yes, I wanted to do a proper job, so I used cable ties. Ensign doesn't fall off and I saved at least three hours drinking time trying to work out from a book which bit goes over what.
I chalked that one up as a result.
itsonlymoney
21 Jun 2003
Exactly............ /forums/images/graemlins/grin.gif
DAKA
7 Jan 2005
Nomadic
I think you would find if you cruised a lot of miles the flag would waft around the cable tie and would fray prematurely.
Thats why I used insulating tape to tie mine on. /forums/images/graemlins/smirk.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
Chas25
9 Jul 2004
I do want to do a propper job!!! /forums/images/graemlins/smirk.gif
