Greenheart
An idle, end-of-season question. I asked something similar before, but I can't recall when, or what the answer was.
I'm in a position to buy a small motorsailer (I'd rather not be drawn on which specifically) but the ones that fit my bill have rigs I wouldn't be proud to own.
They're stunted, probably because the designer expected owners to take token interest in sail trim, and to switch to engine during challenging weather.
The simple Bermudan masthead rig is like a half-size version of that on many cruising yachts, which are reasonably anticipated to be sailed to windward...
...but aboard the motorsailer, the tiny Bermudan rig doesn't bring upwind performance, because the hull and superstructure are so aerodynamically inefficient.
My plan would only be to make the boat sail powerfully when the wind is favourable, accepting that she cannot (and shouldn't be forced to) sail upwind. I'd be converting her from a lazily designed and fitted attempt at a motorsailer, to a proper fifty-fifty.
To that end, I'm thinking the tiny mainsail could be replaced by a gaff main, of significantly greater area (and boom-length), but no extra height. This (I'm assuming) would be better than a taller Bermudan rig which would heel much more without making the vessel better to windward.
I wasn't proposing to rig a gaff mainsail on the existing mast.
Could the extra sail area aft be balanced by a staysail and good-sized yankee on a long bowsprit, or would the mast have to be stepped further forward?
I daresay the steering balance would be wrong at the first attempt. Would dropping hard upwind use from the plan, make this less of a problem?
I'd be ready for plenty of trial and adjustment while enjoying the boat's equally valid use under engine.
Having created an unusual looking vessel (but not so laughable as with her standard rig), just how much bother would a gaff main be, in place of a stumpy Bermudan? I'm assuming the main issue is the running backstays.
Before anybody makes the obvious warning, I realise increasing any boat's sail-plan outside its design requires close attention and ready reaction to conditions, and reefing ahead of time. But many small motorsailers have rigs so tiny, they're only fit for mounting radar on. I'd like to explore whether the sail-plan provided is all the vessel can take, or just aimed at lazy crews.
