pandos
I have done this on smaller boats with a tabernacle and it can be tricky, but doable.
I often wonder has anyone considered a temporary track both sides of the mast base so that the mast is captive but can move forward and back, using horizontal control lines (this would require a pair of bearings bolted through the mast near the base and two pieces of channel iron) then an "A" frame fixed in the cockpit with a pulley attached to the front of the mast, as high up as possible but below the spreaders...
As the mast base is allowed to slide forward, its weight will be taken up on the A frame and eventually will come to rest at the bow and on a crutch at the stern...
This method would get over the really scary point where the entire mast is trying to act as a 12m lever to lift the base up off the deck or to crush the human like a nut cracker....
