crisjones
Generally some pretty good advice from everyone. I would say polyester resin is perfectly adequate for the repairs you are looking at, no need at all for the extra cost and hassle of epoxy.
Grind back the damaged areas inside and out until you get to original, undamaged lay up and then build up from there. Use something on the outside to give some shape (does not need to be perfect) while you start the repair on the inside, this only needs to be stiff card with a plastic bag on the inside - tape it on the hull and put some layers on the inside.
Best to only do 2 -4 layers at a time, wait for it to go off (4-6 hrs) and then add more layers if required. Never be afraid to put too much on - it is easy to grind off!!! Once the inside is done, remove the support and then grind all over the new stuff, the dodgy bits where it joins the existing and anywhere else that needs it. Then repeat the lay up process on the outside, again do not worry about putting too much on - much better than too little. Once this has hardened you can grind / sand it to shape as required before adding a gel coat layer that is also then sanded back as required. Finally finish with paint to match colour.
The best piece of advice I can give is this : it is virtually impossible to repair grp without grinding - before, during and after!!!! Resin and matt are relatively cheap so put plenty on and grind back after, you will get a much stronger job than trying to put the bare minimum on to give the required shape. It is also much easier to produce the required profile with a grinder and sander than with resin, mat and roller.
