bendyone
HI
I have just brought our Hunter Horizon (1985) home for the winter. It has been afloat for 18 months on the same antifoul – not too bad most just pressure washed off. The keels have some rust showing and patches of the antifoul have flaked off the hull. The hull is yellowed around the water line but above that not too bad. The bottom gelcoat was stripped and epoxyed 5 years ago. The decks are good and clean.
My plan is :-
Removal all the antifoul with removal 610 (or is there a better way).
Clean the hull with a mix of oxalic acid and wallpaper paste.
Treat the keels – what is best to use?
Apply Gelshield to the bottom – how many coats?
Apply something to protect the hull until the spring – any ideas?
In the spring anitfoul and polish the hull – again what is best to polish with.
The coloured tape line round the hull need replaceing - what tape do I use? 25mm wide.
Any recommendations on products to use would be appreciated.
<hr width=100% size=1><P ID="edit"><FONT SIZE=-1>Edited by bendyone on 23/10/2004 16:02 (server time).</FONT></P>
My plan is :-
