ChromeDome
It is commonly so, that the tilt range wont hold if you open the throttle. It just slides down, by the prop thrust, to the trim cylinders.
Not sure what you mean RPM and speed reading, apart from what I had above, at 5k RPM it was running at 30-35MPH, this what you mean?You need these to decide if or what change.
If you reach the recommended rpm range at wide open throttle with your normal GW (which you do at 5000 rpm as per my earlier post), the prop design (3 blades), dimensions (diameter and pitch) is ok. Means the engine is loaded right and runs at it's best.NO sure what you mean RPM and speed reading, apart from what I had above, at 5k RPM it was running at 30-35MPH, this what you mean?
I think I'd just rather buy a new prop but I not sure I want to get a QS one if it's going to cost a lot more, I'm not massivly intent on getting top speed
and I'll likely sell the boat in a few years.
I'm sure this would do at £100 plus shipping (I'm in Ireland so shipping will be a little more).
14 x13 Outboard Propeller for Mercury Mariner 13" Pitch 75 90HP 100HP 115HP 125
They sure look original. Being picky and as said…with all metal tanks, especially this age…they can rust inside and try and throw flakes through or into your fuel system. Causing blocked filter or restrictions perhaps.Just a side thought on the current petrol tanks. They look like original ones; the fuel line clip looks the original ancient. Are these still ok wit use or should I invest in new? I don’t even know how to unclip the fuel lines at this point.
View attachment 155838View attachment 155839View attachment 155840
Looks like it’s a 17”. Likely be about spit on for that set up, from what I’m aware around similar boats, engines and gear ratios. Won’t be too far wrong anyway. If she went well enough and within spec, just get another black max 17” suitable for that gear box size. Props listed as suitable will mention a range of something like 75-125hp usually…but not exclusively!So this is the prop numbers. I've no real idea what I'm looking at.
Anybody know how i might see the pitch? One side says 19 and the other 17...View attachment 155920
Unless you are around swimmers regularly then don't get a prop guardThis is the Solas I'm being quoted. ALUMINIUM PROPELLER 3 BLADE 14 x 11 So quite expensive anyway compared to UK prices.
Any UK suppliers that might have this that you'd recommend? I can get delivery to Belfast so same cost for delivery as mainland UK.
Is there any value in me getting a prop' guard?
I'm also going to get those metal fuel tanks out, I can put them back in at sale, would this tank work with my boat? FUEL TANK LTS. 22
I'd have to get the fitting etc of course.
I also rewired it yesterday so a fuse board, solar, battery cut of switch and some extra switches, I think it worked out well, I'll send photos later.
