Help finding blade fuse holder
sailorbenji
20 Oct 2011
Hi,
I'm hoping someone can help me find a replacement blade fuse holder. The only marking I can find on the existing one is "Made in Canada".
It seems unusual in that it has bottom entry terminals, but the mounting holes are on the side.
That means that it is mounted to a "wall", the terminals are underneath, but the fuses can be clearly seen from above. Il. All the ones I find have the mounting holes at the bottom, that is to say when mounted to a wall, the fuses end up facing the mounting wall, which would make access very difficult in its location.
It's a 6-way fuse box.
I've attached a very rough drawing of it. Anyone know, or seen one? I've tried the usuals like amazon and 12voltplanet etc.
sailorbenji
20 Oct 2011
Thanks guys, all the ones linked I've found version of....as someone said, the difference is in all cases the fuses are on the side ie they face you when mounted on a vertical panel, whereas the one I have, the fuses slot in from the top when mounted on a vertical panel.....you wouldn't think it was such an usual thing!
The problem is the fuse box location is inside our nav seat, on the backside of the front face of the seat, so if I use any of the above, the fuses would be facing away from me...and very difficult to see and replace.
wonkywinch
30 Jul 2018
Hamble, UK
Have you tried a Google image search?
penberth3
9 Jun 2017
Thanks guys, all the ones linked I've found version of....as someone said, the difference is in all cases the fuses are on the side ie they face you when mounted on a vertical panel.....
Isn't that a better arrangement? Why do you want to replace like with like?
