AlanRD
Hi
Has anyone tried using Hammerite paint on iron keels. I know the stuff works on gates etc. but are there any problems using it on keels. For example does antifouling stick to it.
Hammerite No 1 Rustbeater is absolutely superb at getting rid of rust on keels. Just wire brush loose paint and the worst of the rust off, sand blasting or rubbing everything down to shiny metal is not necessary. Apply two or three coats and then antifoul over. No other primer is necessary.
Over two or three years I got rid of all rust on my old bilge keeler and eventually did not need to use the Hamnmerite again each year when antifouling.
It is also cheap so you save money as well.
