Why not do away with the shackle? I have been using a bowline in dyneema halyards for 20 yearsI'd be surprised if you have room for a halyard knot in the space of the Witchard shackle, but you could change the shackle.
Why not splice? It will be smaller and less palatable to whatever is hungry at the top of your mast.
Jonathan
What is a bull horn splice?The bull horn splice on my dyneema halyard to the shackle is starting to fray.
A quick Google comes up with a load of different stuff, but only with this thread with reference to rope anywhere near the top.What is a bull horn splice?
I have used a similar method for some time, seems to work well, and as Db says you can get the main up further.Why not discard the shackle. Put a plastic stopper on the end of the halyard retained with an overhand knot.
Double the halyard over & poke it through the eye in the headboard, so that there is a loop on one side of the headboard. Then take the tail of the halyard with the stopper on it & pass it through the loop Then pull the halyard up tight so that the loop now jams the tail in the loop. It cannot pull through as the stopper will prevent that. It should not anyway but it is an extra safety point.
Easy to undo. Does not need a shackle that might come loose. Sail can be pulled up the mast further. Nothing to bind in the mast sheave.
If you do it as I describe, the ball would not actually take any load, as it would be just laying on a free tail end. It is only there in an emergency.With dyneema, there are lots of ways to do it, but seeing the wear, one thing I would do is put a plastic ball on the halyard and see if that takes the wear.
Yes. That's why I was asking what the OP meant.A quick Google comes up with a load of different stuff, but only with this thread with reference to rope anywhere near the top.
Yes. It would act as a buffer between the sheaf and where the halyard meets the sail.If you are suggesting on the halyard above the sail it would seem a pointless exercise. Why would you do that?
https://marlowropes.com/wp-content/uploads/2016/07/Retained-strength-Knots-v-Splices-infographic.pdfWe have used a halyard know on the same type of shackle for about 15 seasons so far (but occasionally end for ended or moved slightly to avoid chafe in other areas of halyard). Works well on Liros cruising dyneema.
I winch tight between two sheet winches before use.
Clearly marginally reduces strength compared to a perfect splice, but generally halyards sized for grip not breaking strength.
In the picture! Looks like a bull horn - this is what I’ve been told it’s called.What is a bull horn splice?
See Jonathan’s reply. A bowline won‘t allow the main to be pulled up high enough.Why not do away with the shackle? I have been using a bowline in dyneema halyards for 20 years
Personally I’d end to end the halyard and re-splice. Splicing with the part of the rope that’s been under tension won’t be as easy as splicing the bit that isn’t loaded in use. Nothing really wrong with the halyard knot though.The bull horn splice on my dyneema halyard to the shackle is starting to fray. Can I cut it off and just tie a halyard knot to the shackle ie. Would this slip on dyneema? View attachment 158649
It will allow it to be pulled up high enough once the shackle has gone. That shackle is a long shackle. I originally removed the shackle for the same reason on an old mainsail that had stretched. There wasn't enough room for a shackle with the Splice making the rope fatter and fouling in the sheave. A bowline can be made shortSee Jonathan’s reply. A bowline won‘t allow the main to be pulled up high enough.
Nothing wrong with that providing your halyards are considerably over specified, as a bowline reduces line strength a more than a halyard knot, and a lot more than a splice.It will allow it to be pulled up high enough once the shackle has gone. That shackle is a long shackle. I originally removed the shackle for the same reason on an old mainsail that had stretched. There wasn't enough room for a shackle with the Splice making the rope fatter and fouling in the sheave. A bowline can be made short
