Halyard to wichard shackle knot
Nothing wrong with that providing your halyards are considerably over specified, as a bowline reduces line strength a more than a halyard knot, and a lot more than a splice.
Almost certainly they will be well over specified on a cruising boat, but worth bearing in mind.
Halyard knot on the shackle is a simpler solution if you are regularly removing the halyard from the sail.
We remove our 10mm dyneema mainsail halyard after every sail. It's been the same halyard for 37,000nm. I like the bowline as it moves the halyard on the sheeve slightly each time. We have cut the end off a couple of times to remove wear, on the old stretches mainsail. It has yet to occur on the current Vectran mainsail as its only done 5000nm
10mm dynema would comfortably meet the description of “over specified” I suspect!
I'd be surprised if you have room for a halyard knot in the space of the Witchard shackle, but you could change the shackle.
Why not splice? It will be smaller and less palatable to whatever is hungry at the top of your mast.
Jonathan
We have exactly that Wichard shackle and a dyneema halyard and there’s plenty of room for a halyard knot on ours.
