Great Yarmouth Haven Bridge
ianc1200
6 Dec 2005
Frinton on Sea
I'm trying to find out what the air draft of this bridge is unopened - low tide, and the what depth of water there is. Can see it has started opening again, but also watched a video of a motorboat coming back from Wells, deciding to not go in at Great Yarmouth because tide wrong, then finding Mutford Railway bridge wouldn't swing, and reverting back to go under the Haven Bridge. At the right state of the tide would a 3.3m air draft/1.1m draft boat get under the unopened Haven bridge? (I'm looking at buying a motorboat, and going to the Broads from Titchmarsh, have done the Mutford Lock route before but it can be a bit of a faff).
Herring Bridge/3rd crossing looks OK at 4.5m at MHWS.
The video I watched;
Leighb
8 Aug 2007
Suffolk
The Broads map by Heron maps, shows it as 2.9m, this would be at average HW Spring tides, you should have no problem with 3.3m aircraft as long as you avoid HW.
pandroid
16 Sep 2001
UK
www.kissen.co.uk
Heron (and Peel Ports) do indeed quote 2.9m for AHWS, but Navionics and others quote 1.8m, presumably HAT. Peel Ports quote 4.6m above chart datum which I guess is definitive.
Plum
6 Jun 2001
UK East Coast
Leighb
8 Aug 2007
Suffolk
Be aware it's now £20 for a passage through and has to be pre booked wether bridge lifts or not, can only be booked in office hours.
Do you really mean you have to pay £20 just to motor under the bridge requiring no intervention by the harbour staff? !! A fee is fair enough if they have to turn out to lift it, it seems that it is just a charge for being daft enough to go to Yarmouth.
ianc1200
6 Dec 2005
Frinton on Sea
The Peel Ports document here says the Haven bridge is 4.3m above chart datum https://www.peelports.com/media/owb...mation-and-booking-bridge-lifts-july-2024.pdf Which is right?
Back in 2019, when I went under it, I calculated it at 4.8m above CD and that worked for me!
Thanks Colin, I believe you then take height of tide off the height above datum you'll get headroom under bridge, so for this afternoon (I'm not doing it today, just trying to work out how to do) the Broads Authority say LW at Gorleston is 0.04m at 15.26pm. So the air draft would be 4.8 - 0.04 = 4.97m. Are there any other factors to allow for - eg river narrower at that point perhaps water higher locally under bridge? But if this is the way to calculate it there's a lot of contingency for a 3.3m boat.
Leighb
8 Aug 2007
Suffolk
I think that charge is simply for the 'privilege' of transiting Yarmouth harbour!
Is this a recent change? I don't remember a specific charge when I went in and out, but it was some years ago and with a yacht that did require a bridge lift. I do remember that the Harbour Authority were very efficient and helpful. I obviously had to buy a Broads Licence, but did that at Mutford when I first entered that year.
Plum
6 Jun 2001
UK East Coast
The Broads Authority do not use Chart Datum (Lowest Astronomical Tide), they use Mean Low Water. My tide tables for Gorleston for this afternoon show 0.7m above CD. So this would make your max air draft calculation 4.1m.
Plum
6 Jun 2001
UK East Coast
and don't rely on the clearance gauge boards for Low Water clearances, see picture of the ones at Gt Yarmouth Vauxhall Bridge I took on the way through.....
Greg2
24 Jun 2002
Not only is there now a charge for transiting the port but, as I understand it, you also have to book regardless of whether you need a bridge lift and if you do need lifts then each of the three bridges has their own booking process and there isn’t a ‘one stop shop’, so it is a bit of a phaff.
We rarely used Gt Yarmouth to access or leave the Broads as Mutford lock is so straightforward and with an overnight stop at the Royal Norfolk and Suffolk as an option it was always the more appealing route.
