Refueler
Heavily utilises, yes. Relies? Technically no.
It's certainly built around the idea of having continuous satellite positioning, but remains usable even in the absence of it. If you lose GPS because a wiring connection corroded through, or you're sailing in an area with jamming, or even if it's working fine but the chart was using an incorrect datum, you can still use the ECDIS (or really any decent ECS system) for navigation. No need to haul out paper.
But, as someone mentioned above, there isn't customer demand for such features even though they are quite simple to implement.
Its positional operation relies on GPS / GLONASS / GALILEO / BEIDOU or whatever sat system opted for.
Once Sat data stops - it becomes a fancy chart display ..... I never said it was not useable - in fact I added :
The only answer is to create / install a completely different system that does not use sats ... but how long before an adversary jams / spoofs that ? Its fine if near enough to coast to use radar or closer and use mk1 eyeball / compass ... offshore to return to using Sextants ....
Blimey that'll cause a stir ... I now have a vision of all those young 3rd / 2nd mates rushing off to learn to use a sextant !!
Because that is the reality ... to relegate the ECDIS to a scrolling chart display ...
Even my old Lowrance plotter ... my smartphone ... my tablets and Garmin UHD displays can all act as chart displays ...
My post was due to your post implied ECDIS was capable of some wizardry if GPS fails ...
