Neeves
Maybe, although I do do this for a living at one of the largest tech companies on the planet so I feel like my finger is somewhat near the pulse on the subject.
On the contrary, it's looking for about 10 different outputs and had hundreds of input parameters. This is where ML really shines, and humans don't, you just need the right person in the chair to get the ML working, and those people are vastly outnumbered by people pretending to know about ML.
I'm pleased to have offered a thread leading to erudite discussion. A conclusion I come to, from your postings, is that it seems to be possible to measure 'something' (vertical movement of a sensor) and as long as you have an ability to measure the impact of that sensor on your yacht then it should be possible derive swell height, maybe not to the nearest millimeter, but to a decent approximation.
A variable not yet mentioned is that in fact as you surf, or accelerate down the wave the bow will bury itself to a greater of lessor degree when it reaches the bottom - and this will all vary with the swell, or wave.
One reason for asking is that our marine forecasts, needs SSB, voice, or internet access, now include swell height and roughly a direction, or ours do, and if the forecast is different to the actual might indicate to one that the swells might get bigger, or smaller in the near future. In some of our forecasts wave rider buoy data, simply wave height, is also provided. Our forecasts also extend well offshore, eg half the Indian Ocean. Between us an NZ we offer forecast between the 2 countries and NZ marine forecast will extend deep into the Pacific.
But if you cannot measure wave, or swell height, you don't know if its going to get better or worse (on the assumption the swell heights in the forecast are accurate).
Jonathan
