MissFitz
The outboard on my Sonata has no astern gear so this weekend I tried turning the engine round to leave the berth in reverse. I didn't want to faff around locking & unlocking it when I needed to go forward again so lashed the tiller tightly & used the engine to steer. The boat certainly went backwards but I didn't seem to be getting much steerage. Is that normal or was I doing something wrong? Is there a better technique for reversing out of a berth without an astern gear?
Also, & this is a really dumb question but...... which way should I have been pointing the turned-around engine when going astern? I canvassed opinions from two very experienced sailing friends, one said in the direction you want to go, the other said the opposite. As per above, it didn't actually seem to make much difference in my case - but would be good to know which is correct!
