D
Deleted User YDKXO
FWIW, cleaning the intercoolers every 2 years is a requirement of the MAN service schedule, certainly for the D2842 series engines. Not sure about the other engine models. And youre right, it does seem to make a difference. When I first bought my current boat, which has these MAN engines, I used to get weeps of coolant in the bilges which I eventually traced to the overflow pipe under the thermostat cap. Having the intercoolers cleaned after the first season cured that and dropped the coolant temp by 2-3degC. I now have the intercoolers cleaned every 2 years religiously despite the humungous costFinally absolutely check that the intercoolers are all clean because they get clogged up and should in my view be cleaned out every two years. Best way to see any problem is run the boat up to 1800/1900 revs and if the coolant temp runs higher than 86 they need cleaning or are going to need cleaning in a short period of time.
