Gludy
As some may know I have been having troubles with my new sailing boat a St Francis Marine 50 foot Cat.
We have never had the reefing system for raising and lowering the main work properly and having now had it looked at the reasons are obvious.
The boat has a LeisureFurl in boom reefing system which in itself is fine - nothing wrong with it but the rigging to the main and the furling drum is a bit of a nightmare:-
Starting at the winch end of the reefing line side
[/url]
reefOntoWinchSmall by SV Suliiere, on Flickr[/IMG]
The problem is two fold.
The stainless steel roller hits the winch drum and scours the drum and the line goes onto the drum at the wrong angle. The roller also used to cut the line but St Francis cured this with a new roller design supplied to us by SFM after all the problems on the Atlantic crossing where we had to replace halyards also replaced by St francis because of the problems they now deny ever happened on that trip. I can prove this with emails and documents. Duncan is simply inventing out of thin air a new history to suit his current wish to hold onto as much money as possible. The noise made on the drum by all this is incredible - grit your teeth time.
The fibreglass in front of the roller plate actually flexes to allow the roller to hit the winch.
[/url]
Bracketremoved StbSmall by SV Suliiere, on Flickr[/IMG]
Here we have the steel roller plate and roller removed. The holes are from changes in sea trials at St Francis. There have been to date three attempts at getting the plate right so this time I have done the spec for the fourth plate and it extends under the jammers so the jammers add additional security - it is 12mm thick and has a much larger counter leverage to prevent the roiler hitting the winch.
[/url]
ReefingLineJamsOrgiansierCutsPlasticSmall by SV Suliiere, on Flickr[/IMG]
Next the lines pass through the jammers to through a plastic guard which the reef line hits and grooves the guard. You can see the groove in the side of the guard.
[/url]
RopeHits Plastic PlateSmall by SV Suliiere, on Flickr[/IMG]
Then into the organiser:-
[/url]
RopeWearsWheelDownSmall by SV Suliiere, on Flickr[/IMG]
There the reefing line jams the simple plastic wheel(no bearings) and then grooves into it. You can clearly see which wheel.
This is because a simple no bearing plastic organiser is being used to do the work of a block!! It has to turn the reefing line through about 60 degrees.
Onto the centre cluster of blocks:-
[/url]
RopeHittingSteelSmall by SV Suliiere, on Flickr[/IMG]
The misaligned blocks actually cause the rope to hit the stainless steel holding the blocks.
This also happens to the main halyard:-
[/url]
MainHalyardHitsSteelSmall by SV Suliiere, on Flickr[/IMG]
The side thrust on these blocks shreds them - see the black plastic on the deck.
[/url]
BlockShreddingPlastic with SidepressureSmall by SV Suliiere, on Flickr[/IMG]
St Francis supplied just plain non-bearing blocks that messed up across the Atlantic and they replaced. Again I can prove this with docments to totally refute no problems crossing the Atlantic myth spread by St Framncis Marine. I have since replaced with plain bearing blocks but the problem is that everything is not properly lined up - blocks should be at 90 degrees to the line and they are not.
Then onto the plain plastic block at the bottom of the mast:-
[/url]
Bottom ofMast with plasticOnlyBlockSmall by SV Suliiere, on Flickr[/IMG]
This is simply absurd for the incredible load it has to take. It should have bearings.
Then from there to the reefing drum up the mast.
OK the wool was pulled over our eyes on sea trials. and a surveyor or any experienced sailor would have picked all this up - just as Lesiurefurl state - the system must have been designed by somebody who does not sail.
So St Francis Marine have managed and supported all the failed changes up to date and I am now left with custom blocks and solutions that are very expensive.
St Fracnis Marine claims that all this is OK - its fine - he was happy with it and all that does is say a lot about him and his standards.
He simply will not help with sorting out the mess that up until now he has tried to sort out - its too expensive to sort so the client pays. Had it been properly designed at the time it would have meant standard high end parts.
This caused an big thread on www.multihulls4us.com but despite joining the thread St Francis Marine refused to discuss the reefing system and declined it as a warranty issue stating all man made things can be improved.
The riggers here cannot believe how Bad this system is - it is not functional.
The large thread is here:-
http://www.multihulls4us.com/forums/showthread.php?t=3451&page=6
The subject starts about halfway down the page.
So I am seeking the views of a wider sailing public.
Is it normal to use a simple plastic no bearing organiser to change a high load line through 60 degrees?
What do you think of this rigging design?
I have given up trying to get St Francis Marine to even discuss the reefing system as they claim it is OK and I find that hard to swallow on a new boat.
If anyone ever wants a lost of boats not to buy - I am your man
