Gludy
Well after all the advice and help, plus ribbing I have receoved from you lot I do now own a boat. Its a Princess 385 - spent the weekend on it before it is being moved by road (glad I did that with this weather) tommorrow.
Nope - not been out her as I want to get to know her first and also need some training.
Taking the radar tower down was a bit of fun and trying to lay it flat almost impossible but I managed it in the end.
As you all said - once the original tender was removed I noticed a bulge on the corner of the one davit - the one that took the engine weight.
I am now, probably going for a 3m valiant (40kg) with a 6hp four stroke engine (27kg) with a total weight of 67kg. Is that not sensible? Or will you continue to rib me about my rib questions?
The boat has a virtually new 6 k.w. Yanama generator and unusually a de-salination plant with a capacity of 10 gallons per hour. No gas on board- a large multi-purpose Microwave come normal oven seems to be a better solution.
The main problems encountered so far are:-
1. One toilet not bringing in seawater - the seacock works ok so I guess the inlet is blocked. In turning the handle on the outlet seacock to the other seacock toilet, I maged to close it never to be able to open it again as the handle has become loose! Result is one toilet does not take in sewater, the other does not let out waste!
2. The windscreen motor to the helm window did not work and was not even connected to its power supply - it seems the motor may have had it. Are these fairly standard motors to replace?
3. The navico radio only steps up in the channel number, not down but there is a Simrad 52 DSC/VHf also supplied, so that not too important at present.
Thas about it really. The boat has new curtains, upholstery and has the washable wall and roof lining throughout.
Overall, I am, so far, pleased with it and look forward to starting my list of 32 jobs (my list so far), so as to improve lots of little things on her and will no doubt pester you all with questions.
All advice - welcome.
Paul
Paul
Paul
Paul
